Hi,
I have a 2007 Saab 9-7x, essentially a Trailblazer masquerading as a Saab.
Anyhow, the issue I have is that sometimes, usually within the first minutes of when the car is first started, when applying gas the car lose acceleration momentarily (like half a second to a second) and then kicks back in normally.
When that happens the STABILITRAK light goes on and then comes off. No engine codes are triggered.
After the first and likely only occurrence during the day of driving (it has happened at later drivings times but very infrequently), everything is fine.
I'm hearing it could be the throttle body. Is that possible at 150k?
Could it be something else worth looking into?
Thanks for any feedback
