Hello folks,
My 2006 Sentra 1.8S is clocking 103,000 and planning to do transmission fluid change (not flush) for the first time. I don't know if the previous owner did it before 70,000 when I got the car in 2010.
Currently, the car jerks when it goes from 1st to 2nd and slight jerk when 2nd to 3rd (it's automatic, but just to give a sense of when the jerk occurs). I don't know if this is same as torque converter shudder. I plan to replace ATF with Genuine Nissan Matic type-D fluid. I wonder if I should add Lubeguard red or Lubeguard Platinum during the first ATF change itself?
I do plan to replace more fluid every month if there is no problem, like those jerks getting worse.
How do the folks suggest me to go about with this one?
Thanks in advance.
P.S. - Just want to make sure that these are compatible with Sentra. Amazon says it does not fit 2006 Sentra.
Thanks in advance.
