Originally Posted By: Silk
They bend because a floor jack lifts in an arc, if you use the supplied scissor jack they don't bend, they also don't bend using a hoist (lift). Using a floor jack is the problem.
This reasoning doesn't really add up to me.
A floor jack has wheels, and as you're jacking up the vehicle the floor jack can roll to compensate for this. A pinch weld would have to be pretty frail from rust or lack of reinforcement to succumb to those forces, it seems to me.
If you're dealing with a super flimsy pinch weld and you have your floor jack on gravel, maybe. In that case, the floor jack wouldn't be able to roll.
If you're jacking on a pinch weld that is the factory-designated life point, and your jack is on any type of finished surface, then that shouldn't be an issue.
