Hi to all. I love this site and learned a lot.
This might be wordy, so PLEASE bear with me....
I have a very strange issue and wanted to touch base with any TH400 experts out there.....
I've been a drag racer for decades and at the present, I have a TH400 in my pro street car. I actually have 2 complete spare TH400s. As a drag racer, I never broke the internals, just the case, when I broke a drive shaft. Just mentioning this, because I've 'freshened' up a few.
The car has a TH400 that has worked perfectly for MANY years, but only gets about 200 miles/year. Last week, I made the mistake of using some 20 year old "Nitro octane booster". It made the car almost undriveable. As I was limping home, I saw a huge cloud of smoke from the passenger side of the engine. I cut the fuel pump immediately. At the same instant, it felt like the rear end locked up.
A braided fuel line had ruptured inside (9 psi) and this 'fuel' landed on the header.
After refurbing the fuel system, I have this weird problem:
(The TH has a manual valve body (reverse) and a trans brake, with a 5500 rpm converter.)
The 1-2 shift is great as usual, but when I do the 2-3 shift, it feels like the transmission is almost locking up! With the converter I use, I can normally downshift from 3-2-1-N at pretty much any speed.
I just cannot connect the fuel issue with the transmission issue.
The TH goes into Park, Reverse, Neutral, First, and Second gear perfectly. Fluid is clean, and full. I've always used a large cooler with all my TH400s.
Any thoughts???
Thank You!!!!
ron
Any thoughts???
Thank You!!!!
ron
