I changed out the front brakes on Mercedes GL450 a few days ago and put in Wearever Platinum pads. There was a pack of lube in that came with the brake pads and I used it on each of the contact points of the pads and without thinking I put some on the sliding pins as well. The grease is kind of a golden brown color and I am not sure if it is silicone or not.
I heard that using regular grease may swell the rubber around the sliding pin causing it to not move freely. Am I screwed or do you think I will be okay? Do I need o go back in and clean out the grease or is it too late ? Thanks
