G Gwoody Joined Mar 11, 2017 Messages 2 Location Washington Mar 11, 2017 #1 Can I use EP 220 gear oil in my 2011 Dodge Ram 1500 5.7 hemi motor. Would this not be recommended?
O OneEyeJack Joined Sep 14, 2010 Messages 7,485 Location S California Mar 11, 2017 #2 What's spec'd in your owner's manual. Would a X-reference help?
Rand Joined Aug 20, 2003 Messages 21,505 Location NE,Ohio Mar 11, 2017 #3 I'd pass its an industrial gear oil with a VI of 97?
A aquariuscsm Joined Dec 30, 2006 Messages 29,558 Mar 11, 2017 #4 You're wanting to use gear oil in an engine?? Why? If I interpreted your post correctly,you asked if you could use it in your "2011 Dodge Ram 1500 5.7 hemi motor"?
Z zeng Joined Sep 1, 2015 Messages 2,876 Location Malaysia Mar 11, 2017 #5 In engine, no. In differential, possibly no problem.
Rand Joined Aug 20, 2003 Messages 21,505 Location NE,Ohio Mar 11, 2017 #6 Originally Posted By: zeng In engine, no. In differential, possibly no problem. Still no, not the right viscosity or properties for automotive use in many locations. For example the pour point is a mere -4f degrees
