I painted my vette with flame red dupont lacquer a long time ago. Since then i stripped and repainted it dupont bb/cc with glamour clear, then years later went over that with House of Kolor uc-35 with pearl. Then laid down a foundation for kandy several years ago and never finished it.
I've rcently started doing some repair on the trans am with duplicolor perfect match rattle cans. This black lacquer buffs out looking better than anything i've seen before. There is a certain richness to lacquer. And it doesnt matter how bad the spray goes on, you can run the heck out of it or back away and spray it on dry. Color sanding and buffing perfects the surface correcting most all mess ups. Unlike clear coat, i can use a rotary buffer on this every month if i want to without break through worries. If i break thru to the primer, simply spray more on as it blends wonderfully.
Once i'm done with the t/a i'm thinking ill use the duplicolor spray gun lacquer on the vette. Mixing clear with their blue base should make a nice kandy.
