Ridgid 44-S heavy duty pipe cutter currently selling for $316 - $426 new
I got this on craigslist for a $20 bill
Heavy like 20lbs
XG7317 for size comparison
As you can see on the end of cutter there is a "guide block assembly" that is spring loaded and held in by a single screw.
I think I can remove this easily if it doesn't work well for cutting or gets in the way/scratches the pretty paint
Cleaned up with a decent amount of WD 40, what should I use to lube this thing?
Heavy like 20lbs
