Let's say you drive your car daily to work. Come home at 5, park it in the driveway until 8 in the morning the following day when you leave for work again.
So everyday, your engine is turned off, sits for 15 hours, then gets turned back on again.
As the engine cools down through the evening and gravity pulls the oil back down in the pan, a higher cold viscosity oil (like a 10W30) which drains slower would not have time to drain down as much as a 0W30. More of the oil would still "stick" to the upper moving parts than with an oil of lower cold viscosity.
It may sound counter-intuitive, but now thinking about it that way, wouldn't it make more sense to adopt a higher cold viscosity oil (like a 10W30) in order to reduce cold-start wear, if the usage pattern is (reliably) 15 hours between engine runs?
