The Amsoil Engine Flush doesn't loosen up chunks of deposits - it dissolves and disperses them so they can be captured by the oil filter and drain out when the oil is changed. It also moderately thins out the old oxidized oil so it drains out more completely. I've used the product on some very dirty engines and it works just as advertised. In particular it will remove residual deposits from engines that have experienced coolant leaks.
