I took this AT out of storage and fired it up. While in DOS the power supply just died... No popping, it just shut off.... Plugged in another AT supply and the PC works.
The problem is that the new AT power supply that I have is not "full sized with large switch" Does not fit the cutouts in the case.
so I'm thinking on getting my original power supply repaired. Going to open it up and look for a fuse or bulging caps. If nothing can be found where may I send a unit out for repair? (National chain preferred)
