Originally Posted By: SlipperyPete
Originally Posted By: alarmguy
What about manufacturers who specify motorcycle specific oil? Would you apply the same reasoning and buy motorcycle oil?
My only gripe with diesel oil is the bikes I've tried it in shifted like [censored]. I would use it in a non-shared sump bike without a second thought.
Absolutely! I have been a long time advocate of using the proper recommended oil in any vehicle, that includes, boats, planes, cars, trucks and motorcycles.
My only question to you would be, what qualifies a product as motorcycle oil?
Someone putting oil in a bottle, jacking up the price and calling it motorcycle oil?
Answer = No, there has to be some kind of standard, that standard would be Jaso. So if a manual is calling for a Jaso rated oil, yes, of course, the oil of choice would be just that.
With that said, then some of the Rotella Diesel oils would qualify as motorcycle oil as it carries the very same claim that it meets the standard.
Some may not know that so called diesel oil is gasoline automotive API rated oil as well, plus the added Rating for Diesel oil and in some Rotella oil, the added Jaso Claim.
ALL Jaso rated oil has to meet Automotive and/or Diesel standards as part of the Jaso approval. THe Jaso approval takes it an extra step for clutch friction.
" Modern motorcycles usually have the same oil lubricating the engine and the wet clutch. For this purpose most of the time the regular friction modified engine oils are not good enough. To make sure that the right oil is used motorcycle manufacturers usually require the oil to meet one of the JASO standards explained below.
The motor oils that meet the JASO T 903:2006 standard can be classified into four grades: JASO MA, JASO MA1, JASO MA2 and JASO MB. The classification is based on the results of the JASO T 904:2006 clutch system firction test.
In order for a motor oil to meet any of the above mentioned JASO standards it must be at least of one of the following quality levels:
API SG, SH, SJ, SL, SM
ILSAC GF-1, GF-2, GF-3
ACEA A1/B1, A3/B3, A3/B4, A5/B5, C2, C3 "
Click here for the source of the above statement
BTW - I hope you know, I am just discussing here, conversation ...
