I was watching some good 'ole tractor pulling some time ago and saw where they would attach the rear tires together thru a hose to make sure the tire psi was absolutely even. The point being, the one with higher pressure would release into the one with less air.
Could this happen when trying to jump start a car via booster cables with the engine off? Would one battery of a higher charge exchange power/amperes/current/watts (whatever) with one of a lesser charge?
Or must the alternator be spinning to accomplish this?
