I know the 8N's used to run with LOW pressure, but I believe I should be getting 20 psi at idle.
Perhaps a new oil pump? I've heard some old timer saying that the pressure relief spring is adjustable, and sludge can cause problems.
This tractor was not used much, just sitting mostly. I really don't want to put it under a load until I am comfortable with the oil pressure.
