Sorry, I'm not on any firearm forums, but it might be maintenance related.
I have not owned my G43 long, and have only taken it to the range three times now (about 250 rounds through it). It's been flawless at the range. I noticed that I need to work on my trigger pull (a lot more noticeable than on the G19), so I put the laser cartridge into the 43's chamber and practice. I pull the trigger, rack the slide to reset the trigger, but 75% of the time, it doesn't catch and the trigger is still dead. I tried this with and without an empty magazine inserted. I did some googling and found a few similar symptoms, but almost all of them were after the owner did some trigger work and reassembled incorrectly. I've never disassembled my unit further than removing the slide, wiping the frame/recoil spring/slide/barrel, then lubing at the tabs.
My frame:
Other picture I found online:
You can see that the yellow line points to a part that is on top of the part with the part number. I've read in my searches that the first digit on the part number should be covered with that other metal part (you can tell that I'm not a Glock expert).
Questions:
Any of you have a G43 and can take a look to compare, also, any issues resetting the trigger by hand racking the slide?
Is it possible I dislodged that part while wiping with a rag?
If it is wrong, can I fix it myself (I'll send it back to Glock if it's a manufacturing issue)?
Thanks for the help!
My frame:
Questions:
