I don't understand this logic. Car is specd for 30 but shears well into 20 but people with uoa don't think it's an issue. Seeing it plenty on turbo or turbo+DI cars.
Then if you ask about going down a grade from 30 to 20 for a 30 specd car people will advise to play it safe and use only what is specced...
Also what about racing? If you track your car it could see oil temps 120C or above. That would mean the oil is then well into a 20 grade if it started at 30 but most engines don't blow on the track... well they do more than everyday driving that's for sure.
Makes sense to me that some may use a 60 grade race oil on the track as the temps could shoot up and the 60 would therefore be more like a 30 or 40 at high temps.
I dunno, does it really make any difference? Can engines specd for 30 probably run 20 30 40 50 and not experience any issues, probably yes.
