My Jeep uses about a quart of oil between 1000 and 1500 miles. It has 75,000 miles on it but has used oil since new. I was never able to get a dealer to fail an oil usage test because it was always outside the limits to fail.
I know this is a common issue with the 3.8 engines. Sometimes the oil usage is worse than others, I guess that is due to weather it is driven on longer trips or shorter around town trips.
The owners manual recommends 5W-20 oil. Any harm to use 5W-30 or even 10W-30 that meets DaimlerChrysler Material Standard MS-6395?
I use PP most of the time but have used Mobil 1 in the past. I believe the Mobil 1 causes more oil usage than the PP.
