Originally Posted By: bigt61
UOA wasn't that bad considering. That screwdriver may have already done enough damage to kill it. Once you start breaking up that carbon by hand, it usually doesn't end well unless you pull the motor apart and go all the way. In this case, not worth it. I'd just button it up and run cheap dino for 3000 mile OCIs with cheap filters. Keep it topped off and hope for the best, you may get lucky - those motors are pretty tough.
How on earth do you think a cheap dino is going to shift what is some serious sludge and varnish, some kind of miracle ??
It will take at least a day for a good car mechanic with the right tools to clean it properly top and bottom. Even if it is fully cleaned there is no guarantee that the engine has not already been damaged. The HG, VVT, turbo and timing chain are all potential weak points for an engine with poor oil flow iisues. Oddly enough when some muppet fails to change the oil the turbo will often fail well before any other parts and that does offer some degree of protection to the block.
For some odd reason some folks think that a major brand idle only use flush can damage an engine during the 10 or 15 mins it is in use, when I've never known of such an issue. If the engine is also a dripper in addition to a black death victim, I would use an engine stop leak additive or switch to a thicker HM oil, depending on how bad the leak is.
This is a 95 Caprice - a beater worth $500 to $1000 at best. Any money spent on trying to desludge it is wasted IMO. Just keep it running on cheap dino and keep it topped off if it leaks. That's it. Save your money for a nicer, newer next car.
It's not going to cost more than 100 dollars to do a few flushes and oil changes and if the engine was running OK before there is a fair chance it will be good after the clean up. It would only be a waste of money or time if you did a full manual clean up with half the top end and sump removed.
There is no need to use expensive oil or filters when cleaning up a sludge monster, although I would use an oil that cleans well after the cleaning. M1 0w40 or Penn Ultra both clean well.
