Pretty impressed with it. I was kind of skeptical initially. Bought it at Walmart for around $6. It's water based and says on the bottle that it won't brown the tires. Application is very simple. Just spray the tire and walk away. Since it comes out mostly as a stream of liquid and is white in color it reminded me of Armor All a little bit. But it worked great and the tires aren't too shiny. Plus I didn't have to use an applicator. I also used it on the all the door jamb rubber seals but I sprayed a microfiber first then wiped them down. I prefer it over Stoners More Shine Less Time which is an aerosol.
https://www.amazon.com/Barrett-Jackson-S...kson+tire+shine
