Finally got around to cleaning my door jams after some muddy roads last month. I knew this was here but I guess cleaning refreshed my memory. This is right where the weather stripping contacts the door. I typically keep it decently clean and the stripping wiped with silicone... although when I got the truck they were very dry and squeaked badly. This is my 2011 with 81k miles, so warranty isn't in the picture and I plan to DIY even if it will look like I did.
I see it two ways. Lightly sand and degrease followed by matching touch up paint. This may work OK and will be less noticeable. Otherwise I will follow the same process replacing the touch up paint with rustoleum rusty metal primer.
Thoughts? Opinions? Door skins and welds are solid (likely thanks to yearly fluid film).
