Originally Posted By: bdcardinal
Originally Posted By: Chris142
R134a is the same regardless of brand. Dont use any with sealers or stop leak
Yup, it is all licensed by DuPont, the real name is DuPont Suva. Do not use anything with sealers, if you do and take it to a shop, you will be on the hook for the thousands in repairs to their equipment.
I understand what you are saying. But,the problem i have with that is in the case of a recently purchased used car.
Using a loosely modified version of My scenario as an example: I just bought this car in Jan.
If i had taken it in before adding anything, would tell them the truth, i added nothing.
so they hook it up, and their works gets all gummed up b/c the Previous owner, (unbeknownst to me) had dosed the system with stop leak.
Why should I be on the hook for equipment when I had no way of knowing the stuff was in the system?
