Being the research fanatic I spent some time reviewing automotive detailing. I came across Optimum No Rinse (ONR) then decided to try it out. This stuff is incredible! Basically you remove the garden hose from your washing routine. Seems scary doesn't it? The method:
1. One cap full of ONR in a 32 OZ spray bottle with distilled water. Mist the panel that you will clean starting from top to bottom.
2. Fill two clean buckets with about two gallons of water.
3. One cap full of ONR in one bucket and two in the second bucket.
4. Use a clean microfiber wash mitt and rinse in the first bucket then second bucket with the two caps of ONR. Squeeze excess then proceed to panel.
5. Wipe in a straight line, one area.
6. Take a dampened microfiber drying towel with the 2 cap solution or mist from the spray bottle, then wipe dry. Follow-up with a second towel and buff.
The finish is incredible, no scratches, no water spots, and leaves a silky smooth, just waxed look.
I also use this stuff for the glass, and as a quick detailer. Good stuff! I will be washing my truck and try to get some pics up.
