Originally Posted By: Miller88
https://www.youtube.com/watch?v=2rmelLUwBi0&feature=youtu.be
Here we go. Took some of me driving around the neighborhood
Doesn't seem too bad? I probably do about the same even with the lower gearing. I do have a habit now of not coming to a complete stop if I can avoid it, which results in starts with nearly no slippage.
I think your probably used to a lower 1st from the jeeps, and if I have a trailer on, or off road, I appreciate the low 1st on the Tracker, but most of the time shifting half way across the intersection is a bit annoying and you have to rev 1st fairly high to come into 2nd at a reasonable rpm.
