For the last 6 months, my 2012 Fit had fail to start 4 times. The first two times it was 5 degrees outside and I had been playing the radios for 20 minutes with the engine off. The third and fourth time, the radio was on while I pumped gas for less than 5 minutes. All four times, I was at the gas station.
The car will jump start just fine using my jump box. This occur so infrequent that it is hard to tell if it is the battery or not. My commute is 40+ miles each way so the battery gets charged up plenty each day. The car always starts in the morning. What should my battery be reading when the car is off and when there is a load? What could be a culprit? Battery, starter, or charging system? It is going to the dealership this weekend so the problem is documented. I drive a lot so it has 25k miles already. I want this resolved or document before 36k miles.
