I think someone here should be able to point you in the right direction. If your truck takes the 3614(fram/supertech number) size, a ST16, ST3600, and ST8 will fit, given enough room.
For a filter cutter, I just use a can opener and screwdriver work fine on most filters.
-T
-T
