This is related to my last post about the guy breaking into my shop to get his forklift. I have a roll up door on my shop just like any other garage door. It has a sliding bolt lock on one side that goes through the track. I always keep a pad lock on top of that. That way if somebody breaks into my shop they can't use a truck to clean me out.
Or so I thought. Looks like bolt cutters made quick work of my Master Magnum lock. Master says "The 5/16 in. (8 mm) Tough-Cut octagonal boron-carbide shackle is 50% harder than hardened steel."
I could use one of those circular locks, to make it hard to cut with bolt cutters, but then you could just cut the sliding bolt on the roll up door just as easy.
How can I lock my roll up door from the inside, so that you need a key inside, and can't just snip the lock with bolt cutters?
