Honda dealers standard OC is 5w-20 blend
by NormanBuntz
09/20/17 10:12 PM
Caprice Burnout
by ls1mike
09/20/17 09:49 PM
Harvey cars parked
by gfh77665
09/20/17 09:34 PM
Overlanding the Pennsylvania Wilds
by SKVenture
09/20/17 09:28 PM
People adverse to weekend plans. Annoying.
by Kurtatron
09/20/17 09:25 PM
2000 4Runner - Walker vs Eastern Cats
by SKVenture
09/20/17 09:24 PM
Lower cost wheel source 2017 CR-V
by Pablo
09/20/17 08:26 PM
VOA Red Line 15w40 HDEO
by claluja
09/20/17 07:02 PM
"Life Hacks" video on YouTube full of BAD advice
by SirTanon
09/20/17 06:36 PM
Opinions on buying a hail damaged/ repaired car
by Blue_Goose
09/20/17 06:34 PM
Euro Cars Used to be Very Reliable
by Speak2Mountain
09/20/17 06:24 PM
Historical Perspective
by Ducked
09/20/17 06:15 PM
Fresh fluid film
by buck91
09/20/17 05:41 PM
Wanger TQ's finally squeaking
by buck91
09/20/17 05:34 PM
Email hosts?
by buck91
09/20/17 05:31 PM
Toyota Tundra 4.6 vs. 5.7
by zfasts03
09/20/17 03:45 PM
iPhone Wallet alternatives for Android
by Alfred_B
09/20/17 02:59 PM
2017 Winter Tire Tests
by SubLGT
09/20/17 01:41 PM
United Airlines 747 Sendoff
by DeepFriar
09/20/17 01:19 PM
Funny or odd safety signs at work or other places
by 97prizm
09/20/17 12:01 PM
notso5, SherriWacker, garyts95, phillipgolden, Ebuks
62887 Registered Users
84 registered (77GrandPrix, Andrew_Svoboda, alphadog, andrewp1998, 4WD, 7 invisible), 1771 Guests and 11 Spiders online.
62887 Members
66 Forums
271143 Topics
#3162381 - 10/21/13 09:14 AM 91 dodge truck 2wd wheel bearing torque procedure
ram_man Offline
Loc: southern mo
My friend went to replace his wheel bearings and the chilto a book he said says 100ft lbs on the nut to seat the wheel bearings. That does not sound right.
He now had the truck spew grease out and lock up. So something is wrong. Does anyone know the procedure on tightening the hub?
Seems to me it would be like ford or Chevy 20-30 lbs and then back it off to finger tight basically.
2014 dodge dart GT "mine"
2013 Dodge Dart limited "hers"
1995 Dodge ram 1500
#3162387 - 10/21/13 09:20 AM Re: 91 dodge truck 2wd wheel bearing torque procedure [Re: ram_man]
robshelton Offline
Loc: Winston-Salem, NC
I'm not sure, but that sounds more like the 4wd spec. Without knowing any different, I'd have done it as you described, seating the bearing and backing off.
1993 Camry 2.2 AT 429k - How far will it go?
1999 F150 4.2
2000 Camry 2.2 AT
#3162405 - 10/21/13 09:37 AM Re: 91 dodge truck 2wd wheel bearing torque procedure [Re: ram_man]
Cardenio327 Offline
Loc: Oaxaca, Mexico
Verbatim from SKF bearing torque booklet:
Tighten hub nut to 30-40 ft-lbs/37-50 Nm
while rotating wheel. Back off and finger tighten.
Install cotter pin.
Front wheel bearings 1991 2wd D150/250/350
'08 Honda C90ST Super Cub 15w-40 mixture of Delvac & Rotella
'08 Honda NX4 Falcon 5w-40 Delo 400LE
'09 Honda Fit LX 0w-20 PP
#3162481 - 10/21/13 10:40 AM Re: 91 dodge truck 2wd wheel bearing torque procedure [Re: ram_man]
Zaedock Offline
Loc: Massachusetts
The 100 ft lbs is to seat the new bearing races in the hub.
The tightening sequence is as posted above.
2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2004 Malibu Maxx LT
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
