Originally Posted By: bdcardinal
The nut on the outside needs a very specific torque.
This is true. I usually sell a new nut with new sensors, they don't come with on Mazda. Ford uses a rubber stem attached to the sensor on the newer systems. The older ones were a band type with the sensor in the drop centre of the wheel 180 degrees from the stem.
I serviced a brand new Mazda CX-5 today for a flat repair and it didn't have sensors! I wish my '09 Mazda6 was like this as it'd make it a little easier to have different sets of wheels. From what I gather they utilize data from the ABS/DSC/Trac system to determine if a tire is low, much like the new Volkswagens I've had come in.
Dill and Schrader are what we use for rebuild kits, they usually for the most part replace the rubber grommet, grommet seat washer if any, the retaining nut/washer and the valve core as necessary on the aluminum stem sensors, and for some of the GM/Ford the Dill kit replaces the rubber stem (with core pre-installed) and the screw. The bugger for me is the rebuild kits for Honda/Hyundai that make you twist past an initial torque stop then tighten to spec; I've had two of these require so much force to go past the initial stop that it strip the threads of the retaining screw that attaches the stem to the sensor and necessitated replacement of the stem. Could have been a bad retaining nut, or just a stem/screw that was worn, but in either case I prefer the design where it's like a t-bolt that slides into the sensor as I've never really had an issue with these.
