Hi All. Recently changed the oil in my 2011 GLK.
Used M1 0W-40 and a MANN 718/5x as per MB requirements.
I used an oil extractor and got ~6 litres out.
Then put back 5.7 litres, figured I'd see how it went and add more if needed.
That's when the ticking started. Low oil, I thought. But the dipstick constantly reads high! In fact it reads that its over the max line, even after leaving it overnight.
I didn't change the filter immediately as I had the wrong cap wrench. That has been changed now, but the symptoms remain the same.
For the life of me I can't reconcile why it would tick and read full or even overfull on oil, unless the dipstick is catching oil half way down the tube, but surely that stuff wouldn't stay on the side of the dipstick tube for days on end?
What's the best way to proceed here? Should I take ~1L out and see what happens to at least clarify if we're too high or too low? Thanks
