Hello All,
After doing much reading here (very impressed) and coming up on my second oil change for my used truck I am seeking some advice on what brand of oil to go with long term.
2002 Ford F-350
5.4L v8 modular engine (just shy of 120,000 miles)
Basically I am wondering do I need to go with a "heavy duty engine oil" for this?
Will it help me long term as far as wear goes?
Almost 3,000 miles ago I changed the brownish oil that was in when purchased. I used a stock Motorcraft filter (I won't use anything else on this or my 1998 f150) and MOBIL 1 synthetic 5w-20. I have no problems with the Mobil 1, I just buy it because it is popular and was on sale at Walmart. I had considered Motorcraft (blended syn/dino?) and pennzoil syn. I haven't been doing my oil changes for the past ten years and just recently (because I dont need to jack this truck up really) decided to grab the reins again.
I check the oil about every 300-400 miles and it is just now starting to turn from golden to becoming a little discolored.
Mobil 1 is a great brand name of course, and I believe in the product.
However, the recent posts of most frequently used oil (at least in 2010) shows me that alot of the forumites here really like PENNZOIL, which I used on my sludge prone 2002 Toyota Camry (until I sold it in 2008 with 140k miles). I had the camry changed at a local lube shop that used pennzoil as their stock oil. I don't remember if I was using synthetics, I dont think so. At the time I thought synthetic oils would "leak", after my experiences over the years I do not believe that anymore. Especially after using normal synthetic 5w-20 on this f350 and having no leaks and the truck runs great!
Which product (I am leaning towards Pennzoil Ultra) would you suggest for basic LONGEVITY of the engine and to run cleanest? I do not have any leak problems, plan on using 5w-20, stock motorcraft filter, and I do not use any oil additives (maybe MMO down the line). I know 120k is "high mileage"... Do I need a HIGH MILEAGE oil? Is PCMO ok to use (it seems to be fine)?
These "modular" v8 engines by Ford DO NOT do well with heavy weight oils, mine was factory specd for Motorcraft blended syn/dino 5w20 and I have no reason to believe it hasn't been used for it's life since I purchased this from a mechanic I know personally. It has "small oil passages" from what I have read and it runs (and COLD STARTS) best with 5w20 from my understanding. It does fire up and run darn smooth, so I don't feel like straying as far as an oil weight goes. Should I feel this way?
Thanks for all of your advice ahead of time. I know I can be long winded....
JC
2002 Ford F-350
JC
