JHZR2
Staff member
It's that time of year when pollen and maple trees make a mess of everything. While paint is easy to keep up, door jambs and trunk gutters (just outboard of the trunk seal), as well as fender areas, under cowl areas, drains and flat areas inside fenders need cleaning, but its super hard.
Mny spaces are too small to fit a hand in to even remove leaf litter or maple seeds. Not everything needs to be polished and waxed, but leaf litter and dirt holds moisture which could cause rust, and dirty door jambs and such places just look messy. Plus pollen and water and road dirt make a nasty cement in many spots. Cowl plastic covers aren't always removable, but bending them to get hands under can damage or crack them.
So is a vacuum with a flexible pipe or something like this required? Any other tools? What about cleaning? Water? Quick detailer? Sponge on a stick? Paintbrush?
How do you remove solids, dust and grime from these impossible to reach areas? What do you then cover them with for protection, rubber dressing, etc?
Thanks!
Thanks!
