Okay, you guys have made a believer out of me regarding Lucas. Starting today, I'm going to flush the fluid out of my AXOD metric transmission via the hand pump through filler tube method. Plan on pumping out three quarts before driving to work. Then at lunch, three more, then home this evening, three more, etc till I flush out all the fluid with Lucas additive, (bought four gallons Supertech brand last night).
Now, my question. If innards of tranny are varnished, should I use something like Seafoam tranny additive to clean varnish or should I wait and see what new fluid does and if problems persist, then use seafoam?
Thanks - Glenn.
Thanks - Glenn.
