Originally Posted By: RiceCake
R-134A is a replacement for R-12, you can just recharge with 134.
NO, NO, NO.
OP, find out if it was an R12 system or R134a. R12 is still available, and shops install it. The performance with R12 will be superior to R134a and easier on the old components in the system due to lower operating pressures. So find a good shop that still works R12, the prices have come way down on the refrigerant and youll be happier.
If the system is open, might as well consider cleaning or replacing the orifice or expansion valve, and sapping as many o rings as you can.
You will absolutely need to replace the receiver dryer, youll need to add some oil, and pull a solid vacuum on it, and ensure that it holds for 30minutes or more. If not, find the leaks with a mixture of nitrogen and R22 from a sniffer, then fix the leaks. I doubt you have any though, and you know what youve opened up..
After pulling the vacuum and ensuring that the system is tight, then add R12 to the correct mass and go on your way.
Good luck!
