MMO is not a good two stroke oil. Stay away from using it as a partial replacement for normal 2t oil. It won't clean your engine, as MMO combusts, it produces significant deposits.
Conventional 2t oils of all types are engineered to scavenge deposits. Diluting the oil by adding MMO simply reduces the ratio of the additives doing the work.
Quite simply, don't do it.
