Have a versatile 305 mfwd tractor with a univance powershift transmission and shared reservoir with the hydraulic system. Have run caseih hytran in the past but want to simplify things and run mobil 424 in this tractor and two others to eliminate contamination of oil from implements the tractors are operating. Also have a Kubota tractor that uses kubota udt and I believe mobil 424 is a direct replacement.
So is mobil 424 as good as hytran and work well in the hyraulic systems in these tractors? Do the specs of mobil and hytran compare favorably? I believe hytran is noted for its ability to keep water in retention without degradation(up to 1%), but can't find any info for mobil 424. This can be a problem in farm equipment because hydraulic systems naturally build condensation and don't heat up enough to burn it off like engines do. Thanks in advance for any and all info.
