I tried to loosen 1 of the external torx bolt with standard hex socket in preparing to replace the thermostat housing of the E430, the bolt didn't move at all. I'm afraid if I use too much force I may strip the head and get bigger problem.
Why MB decides to use external torx bolts on may area of the engine ? The valve cover bolts are external torx, the thermostat housing uses external torx ... Why don't they just use standard hex bolts ?
Now I have to buy a set of torx sockets to be able to do some work on the E430.
