Hello,
I'm looking for high temp > 1000 degrees oil to use in casting. I've searched for Silicon Die Cast oil but don't find any specifics or actual items. Could anyone route me to where I could find this and in a small amount?
Maybe this should be a separate thread but same application but I'll try here.
Can I thin out Permatex Ceramic Brake Lube to make it an oil and retain the high temp qualities? It's good to 3000 degrees and I only need 1000. Is there an oil or something to mix to make it thin as an oil?
Thanks
Thanks
