I just bought a set of rotors and wagner thermoquiet ceramic pads for the front of my explorer. I was only planning on doing the front for now but I see the rebate for the pads ends on the 30th, so I think i'm going to do the back set also.
The problem is, I can't get the ceramics in the rear around my area, so they will have to be the semi-metallic thermoquiets.
My quesiton is, do these pads have different bed in procedures, or is it just generalized? The procedure for the ceramics are 30-0, wait 30 sec, repeat 20 times. It also says they are not fully bed in until about 200 stops.
Should I get the fronts bed in and then install the rear? Or should I just do it all at once?
I've never had thermoquiets but I'm not a big fan of advance auto's wearever line. Thanks guys.
