Originally Posted By: modularv8
Originally Posted By: Rand
Originally Posted By: johnsmellsalot
I think the only reason they call it advanced fuel economy is because it is 0W-30 instead of 5W-30. That means it has a lower viscosity when cold. Once the car is at normal operating temperature, it's probably not going to give you better gas mileage.
not true.
Its a different additive formula for lower friction.. which isnt the same as lower wear.
It also has better low temperature properties but that's secondary to the lower friction additive package.
Take two motor oils with the exact same viscometric properties (same HTHSV @150C), the one with the lower MRV/CCS will provide greater fuel economy across all operating temperatures. Meaning, that even at typical engine oil operating temperature (~200F), the oil with the lower CCS/MRV will provide greater fuel economy at that temperature. One study showed the difference to be about 3% increase in MPG. Depends on the CCS/MRV value relative to another motor oil. As far as M1 AFE, these two offerings have the lowest published CCS/MRV by a large margin over other synthetic motor oils.
I believe XOM is achieving these low CCS/MRV values with higher quality base fluids. The other way would be to add more VM polymers, but that doesn't seem to be the case since M1 0w20 AFE does not sacrifice HTSHV @ 150C to achieve the low MRV.
This from XM seems to back up what you say in regard to the higher base stock with the AFE oils. See just below the crankshaft. Here is the link.
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_Advanced_Fuel_Economy.aspx
