So I don't know if you guys are all that familiar with Z's but the 1990-1996 Z's like to grind going into 2nd and 4th gears anywhere above 3,000rpm's. I'm not sure what the past owner ran in the transmission but I switched it to NEO synthetics transmission fluid about 5,000 miles ago or so and it might have helped the grind a little bit but I was hoping for more. I do not believe it has anything to do with the NEO fluid since they have a crazy reputation for awesome products and they supply 80% of the cars at Le Mans. I think it would be a great fluid if your transmission was new and didn't have any prior issues. So back to my question what do you guys think I should try to help out my issue a little bit without replacing the transmission of course since its really not THAT bad. I was looking into some Redline products and some from Amsoil and I was wondering how comparable the two were and if anyone has any options on which would be best. Thanks guys.
