Hi guys, need some help with this one.
I turn the key in my Dad's 2006 V6 Camry and nothing happens, no clicking or anything. I thought it was the starter solenoid so since I couldn't find just a solenoid I bought a remanufactured starter/solenoid. I installed it tonight and the results were the same, nothing!
I know the battery is fine, it is relatively new (less than a year). I can hear the fuel pump start and the lights and radio come on.
I looked at the fuse box but I really couldn't determine which fuse it was. I saw an ignition fuse (15amp) but I couldn't even pull it out with a long nose pliers and I don't have the proper puller. Should I be looking a fuse or relay? Thanks in advance for your suggestions...
