DI engines would be mostly fine if we could use lean stratified charge as they need to be run. Credit our stupid EPA for messing up the works on that.
Originally Posted By: VNTS
I would avoid it and look elsewhere until they have been out a while. Note most non-DI turbos wont have any issues provided you change the oil at reasonable intervals and better yet run a good synthetic in them.
Dont really see how that is the case, assuming the conditions are the same and the oils are the same. The turbo may be run a bit richer in some conditions, but most of the concerns are about deposits and lack of solvency on the valve backs, which doesnt get fixed based upon turbo or not.
