In both cases, NLGI 2.
At my shop, I am about to switch to one of these two greases, for all uses, from chassis lube to wheel bearings, including in the vicinity of high-temp disc brakes.
From the company spec sheets, I see the following:
Delo Retinax
75---60------Timken OK Load, lb.
500--250-----Four-Ball Weld Point, kg.
0.45-0.45----Four-Ball Scar Diameter, mm.
To me, it appears that the Delo grease is the better product, but is there something else I should be looking at?
Delo Retinax
