I own a late model Simplicity Large Frame machine right now and I'm very pleased with it. If I were to trade up, this is my choice:
http://www.yamaha-motor.ca/products/products.php?section=td&model=3537#contentTop
YAMAHA
Price Tag
$3,999 msrp*
YS928J
The flagship of Yamaha snowblowers!
CAPACITY
Clearing Width 71.5cm (28 in)
Housing Height 51.0cm (20 in)
Blowing Capacity 50 tons/hr
Maximum Blowing Distance 16m (52 ft)
DRIVE SYSTEM
Axle Rubber track
Transmission Hydrostatic
Speeds Infinitely variable
Ground Speed (km/h) Forward: 0 ~ 3.2
Reverse: 0 ~ 2.4
AUGER SYSTEM
Type Dual stage with "Shock Protector"
Diameter 350mm (13.8in)
Drive Electromagnetic
Height Adjustment Gas assist
CHUTE CONTROL
Rotation Electric
Deflection Manual, two-step (remote lever)
Turning Radius 220º
Chute Material Steel with inside plastic liner
ENGINE
Model MZ250E
Type 4-stroke air-cooled, OHV, single cylinder
Displacement 251cc
Maximum Horsepower 8.5 hp
Starting System Electric 12VDC battery type (std)
Ignition T.C.I.
Recommended Fuel Regular unleaded gasoline (PON 87)
Recommended Engine Oil Yamalube 5W30
GENERAL
Fuel Tank Capacity (L) 6.7 litres
Engine Oil Capacity 1.1 litre
DIMENSIONS
Wet Weight 169kg (373 lb)
L x W x H mm (in) 155.8 x 73.0 x 110.5cm
(61.3 x 28.7 x 43.5 in)
WARRANTY
Private Use† 2-year, limited.
Commercial Use† 1-year, limited.
