Originally Posted By: semaj281
What is the acceptable range for "good" oil pressure?
I've always seen the 10psi per 1000rpm rule, but then again I've seen a lot of cars getting 40+psi at hot idle.
My Mustang idles at about 850 rpm, so that would mean 8.5psi is ok, but that seems low?
It can vary a lot with engine tolerances, especially with factory standard volume oil pumps that put out more or less the minimum flow needed (extra flow steals power and lowers efficiency, so the factory doesn't use HV pumps except in performance-oriented engines).
I have two essentially identical Jeep 4.0 engines (OK, the 01 has distributorless ignition, but they're still basically identical when it comes to heavy internal parts). The 99 has 140k miles and idles with about 25-30 PSI when its been run hard and is fully hot. The 01 has only 85k miles, but idles with about 12 PSI when hot. Neither has any odd noises, and both have good UOAs. Both run at around 40 PSI when they're hot at highway speed (~2000 RPM). My guess is that for whatever reason, the 01 simply has some larger oil clearances, either in the oil pump itself or in the bearings.
