Oil not more that 3 months old, light footed driver, 9mi commute. Lots of highway 70-80mph with kayaks on roof. 22mg ave with premium (93) gas. 155K mi on engine, Mahle (OEM) oil filter. PureOne air filter. Winter/spring driving.
I'm suprised that after 5k miles of easy driving, the TBN is ony 2.6...I know TBN drop isn't linear, but we've all seen conventional UOA's at this mileage with this much TBN, and more.
Makes you wonder what spending the extra $$$ for M1 gets you?
The M1 in that UOA is 0W-40 which has a much higher starting TBN than M1 10W-30. Also sump size greatly affects TBN retention and MB engines typically have large sumps...not sure about this Volvo engine.
Engines and sump do make a differance. With my Focus(4.5 qts cap.) after 10K I had a TBN of nearly 4.0 with M1 5-30EP.
Maybe it's retention kicks in around 3,some oil's are known for that,goes down fast then holds.
Uhh,I think I'd try some dino Valvoline,Havoline,Castrol,Pennzoil,well,you get the idea. 1/3 the cost and they are hydrocracked as well. Best buy would be Chevron Supreme or Shell 10W30 @ Fred's.
