Here's the dimensions in case you want to see how it fits up with your current filter:
P550117
CARTRIDGE LUBE FILTER
Application Details
Lube Filters Product Attributes
Length: 8" (203 mm)
Outer Diameter: 4.02" (102 mm)
Inner Diameter: 0.55" (14 mm)
Efficiency 99%: 20 Micron
Primary Application: CLARK EUCLID GMC
Application Note: 5572425 (MILITARY SEN.)
Alternate Part: P550300-COTTON MEDIA
Product Group: F
Here's the WIX version - these are bypass filters
Part Number: 51503
UPC Number: 765809515031
Principal Application: Deutz Tractors, Transicold Refrigeration Units
All Applications
Style: Cartridge Lube Metal Canister Filter
Service: Lube
Type: By-Pass
Media: Paper
Height: 8.039
Outer Diameter: 4.092
Inner Diameter: 0.567
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
15039 5.125 4.375 0.070
15067 4.970 4.770 0.125
Apparently this filter was used extensively on 2-71 through 12V71 engines over various years.
applications
L@@KIE-L@@KIE!
GRAY+Marine D260 (V8)
GRAY+Marine D427 (6 Cyl.)
GRAY+Marine D572 (V8)
GRAY+Marine D572D (6 Cyl.)
GRAY+Marine D802 (6 Cyl.)
