Picked up this Honda HR214SX for free this week. An older lady just wanted it out of her garage. Years ago it started to run a little rough and her husband "tinkered" with the carburetor. After that, it never started again. They decided to hire landscapers and never looked at the old Honda again.
It's in very good shape, a little dirty but it's all superficial. This thing is built like a tank. Weighs nearly 100lbs. The deck is very thick aluminum. It has a 2-speed drive system which appears to be shaft driven. I've never worked on an OHV small engine so it should be fun. I've got the bag and it is also in good shape.
She's got spark but still won't even sputter if I spray ether in the carb. I know the carb needs rebuilding and I'll have to go through the whole fuel system, but I still thought I would get some sign of life with the ether. I'm hoping a valve isn't hung up, but I'll check compression tomorrow. Even if I have to spend a few bucks to get her running again, I really don't mind. I would rather push this old behemoth around than some made in China POS with a stamped steel deck that will rot through in a few seasons.
Anyone familiar with this engine? It's a GXV120. I'm wondering if there are any weird quirks I should watch out for.
