We're kind of veering off topic here, but it's an interesting discussion nonetheless. So, are there any specific recommendations on how to point the wireless antennas depending on your application? For example, I've read that if all your clients are on the same floor, you should keep the antenna(s) in a vertical position, whereas if your clients span multiple floors, keeping the antenna(s) in a more horizontal position would work better.
In my case, the wireless router (WRT54G running Tomato) is in the basement of a 2-story house. I tried various antenna positions, but haven't observed much difference in signal strength (using Network Stumbler). Are there any good (and free) tools to measure wireless signal strength that I can use to measure this?
Pole type antenna transmit in the direction "orthogonal" or perpendicular, to the axis of the pole. That's why if everyone is on the same floor you should stand it up vertically (then it transmit horizontally).
