So, this is a well known issue - many/most USB3 hubs spew out some noise in 2.4 GHz range that interferes with other close by devices that also operate in that range (wi-fi adapters, bluetooth receivers, etc.).
I've got a Jabra USB bluetooth dongle. I can't connect it directly to the computer because I don't have enough USB ports, so I'm forced to use a USB hub, but when I plug it into that USB hub, audio quality is despicable because of said interference. Would getting a USB extension cable to distance that dongle from the USB hub help fix this issue? I've read that this USB3 hub interference only happens at a very short range.
I've already ordered an extension cable. Just wondering if there is anything else I should try?
